Teflon Tape Or Pipe Dope An Anode Rod? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2009, 11:21 PM   #1
Rewards Points: 2,906
Teflon tape or pipe dope an anode rod?
The question of replacing anode rods in a water heater came up in another thread.
My question is this:
How can you use pipe dope or teflon tape on the threads of the new anode rod without compromising the electrical connection between the anode and the metal tank?
I suspect the answer to this question is that if you tighten up the anode rod well, there will always be some metal to metal contact between the threads. If there wasn't, your connection isn't tight enough.
And, the current flow out of the anode rod is so tiny that you wouldn't need a very good electrical connection between the anode and the tank.
Does anyone have any ideas on how best to install the anode rod to ensure good electrical conductivity between the anode rod and the tank?
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-08-2009, 06:39 PM   #2
Don't know it all, yet!
Still learning!
Didn't know that there was a concern for electrical properties on replacing anodes.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 02-08-2009, 10:00 PM   #3
Rewards Points: 1,088
There exists conductive tape, although it may not be meant for plumbing applications.
handy man88 is offline   Reply With Quote
Old 02-08-2009, 10:12 PM   #4
I don't think this is a concern as the tape or dope would fill the low points of the threads. When I have removed threaded fittings in the past the tape / dope did not cover the entire thread of the fitting.
Reilley is offline   Reply With Quote
Old 02-08-2009, 11:42 PM   #5
Yeah, Reilly's right. Whenever I've removed taped connections, the crests of the thread were bare, and all the tape was packed into the thread valleys.
Downunder:
If your anode rod isn't in electrical contact with the steel tank, then effectively you don't have an anode rod. That's cuz the anode rod uses galvanic corrosion to protect the tank. Basically, it corrodes instead of the tank (just like the zinc coating on galvanized sheet steel protects the underlying steel from corrosion). And, to have galvanic corrosion you need three things:
1. two different metals
2. those two different metals also in electrical contact, and
3. those two different metals also both in contact with the same electrolyte to complete the circuit
If you don't have all three, you won't have galvanic corrosion of the anode, and so no galvanic protection of the steel tank. So, having electrical contact between the anode rod and the steel tank is critical. Without it, you may as well have a steel plug in the hole instead of an anode rod.
That's why I was concerned about the teflon tape or pipe dope interfering with that electrical contact.
Teflon tape or pipe dope chickenboo Plumbing 50 06-29-2011 09:16 AM
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 03:55 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 02:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
