Teflon Tape Or Pipe Dope - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2007, 10:10 PM   #31
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
I like leak lock on LP lines, it seals and locks the joint up from any vibration.
MechanicalDVR is offline   Reply With Quote
Old 07-23-2007, 09:08 AM   #32
RippySkippy's Avatar
Originally Posted by Ron The Plumber View Post
...Now we use a combo of teflon tape with pipe dope on all metalic male water fitting and pipe, this ensures it will have a possitive seal each and evreytime.
Ron, you don't know how much time you saved me...I just plumbed a Weil McLain system, and decided to try this on the treaded fittings and man, that the cats...not a single leak. You 'da man! (that's a good thing!)
RippySkippy is offline   Reply With Quote
Old 07-23-2007, 09:13 AM   #33
Journeyman Plumber
Ron The Plumber's Avatar
Yep, I hate having to take pipes apart do to a leak, I like to do it one time and one time only.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-29-2007, 07:06 PM   #34
Should I use tape or dope on a hydraulic oil pressure connection?
The connection is galv. pipe to control valve.
curt364 is offline   Reply With Quote
Old 11-29-2007, 08:13 PM   #35
Journeyman Plumber
Good question.
Old 11-30-2007, 05:30 AM   #36
Thanks Ron
Old 04-03-2008, 08:17 PM   #37
Ron the Plumber,
You said: "Now we use a combo of teflon tape with pipe dope on all metalic male water fitting and pipe, this ensures it will have a possitive seal each and evreytime."
What is the method for this on brass water connection? Dope on male thread and then wrap it in tape?
Thanks,
William
DIY Guy is offline   Reply With Quote
Old 04-03-2008, 08:25 PM   #38
Journeyman Plumber
Originally Posted by DIY Guy View Post
Ron the Plumber,
Thanks,
William
Wrap with tape and apply pipe dope on top of the tape.
Old 04-03-2008, 08:34 PM   #39
Thanks Ron.
Old 04-04-2008, 01:05 AM   #40
I Agree with Ron, I always use teflon tape with megaloc on my metal water lines and i couldn't tell you the last time i had a leak because of doing it that way.
plumber Jim is offline   Reply With Quote
Old 04-07-2008, 11:14 PM   #41
Doing it myself
Alan's Avatar
Rewards Points: 2,086
On compression joints, but sometime I will use pipe dope at the point of seal on a compression joint if it's brass. But it's not needed.
Also any threads that actually seal via a gasket or O ring shouldn't need any tape or dope IE : Stainless flex supplies, WH flexes......
Journeyman Plumber
Old 04-07-2008, 11:15 PM   #42
Doing it myself
Alan's Avatar
We're actually told the opposite over here...... if you're using both, the female threads of the fitting should have tape in them.....
Journeyman Plumber
Old 04-08-2008, 10:18 AM   #43
Journeyman Plumber
I see what your saying, it does not matter which way you apply it, they both serve the same purpose. I find it easier to apply the pipe dope after the tape, keeps my fingers clean.
But do as your told.
Old 04-10-2008, 11:53 PM   #44
Doing it myself
Alan's Avatar
I agree wholeheartedly, although I think that I prefer to just omit the 'goop' altogether whenever possible.
Journeyman Plumber
Old 05-05-2008, 08:32 AM   #45
HELP !! I made a clasic weekend warior mistake. While installing a gas grill over the weekend I used a dope product on a brass to brass connection which (now that I read the instructions) is really meant for CPVC piping. The product is called real-tuff. Will this connection be ok as is or must I redo with a differnt dope?
Thanks.
tsansone is offline   Reply With Quote
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 03:55 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 02:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
