Teflon Tape Or Pipe Dope - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2007, 07:23 PM   #16
Union HVAC Tech.
Teflon tape was originally meant to replace wicking.
I use teflon tape on plastic pipe fittings.
Teflon with (Hercules)pipe joint compound on brass to brass.
Teflon with Pro dope on copper to metal fittings.
Grip on gas lines over 3/4".
Leak lock on refrigerent or oil piping.
X-pando on large piping (ie boilers).
Teflon paste or Megaloc on small gas piping
If you read the Rector seal can you will see it is supposed to be left to set for a while before pressure is applied.
Often the specs on a job specify what dope is to be used on what piping.
I am a United Association pipefitter for over 20 years and have seen many trends come and go but there are some old hold outs.
bigMikeB is offline   Reply With Quote
Old 06-23-2007, 04:47 PM   #17
That one Guy's Avatar
To much pipe dope on a gas line will get inside the pipe and spread out like a spider web.
That one Guy is offline   Reply With Quote
Old 06-25-2007, 12:36 PM   #18
Do you guys use teflon tape on pvc fittings no matter what, or do you wait until it leaks and then use it?
Is Teflon tape on pvc joints a requirement?
Jack Hass is offline   Reply With Quote
Old 06-25-2007, 07:11 PM   #19
Union HVAC Tech.
Always
Any pipe joint needs some type of thread sealant. So, yes
always use it on plastic threads.
Old 06-25-2007, 07:13 PM   #20
Journeyman Plumber
Ron The Plumber's Avatar
Use teflon tape always on plactic male threads when dealing with water.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-26-2007, 03:14 PM   #21
Longtooth's Avatar
Teflon tape increases the OD of the male fitting, too much will crack a plastic fitting (fmoe) . I prefer dope with teflon. I recently read (from a reliable source) to only use dope on 3/4 of the male thread, the rest will fill in and not get to the inside of the pipe. I'm a mechanic, not a plumber, so sue me if I'm wrong.
Longtooth is offline   Reply With Quote
Old 06-26-2007, 08:00 PM   #22
Journeyman Plumber
Pipe dope in the male thread water only, will make it too slick, too slick will cause you to overtighten, take it from a pro in the field.
Old 06-26-2007, 08:55 PM   #23
Union HVAC Tech.
Ron the plumber,Water only?
What do you use on male threads when it isn't water? And what else do you use plastic pipe for?
Old 06-26-2007, 09:29 PM   #24
Journeyman Plumber
I'll use pipe dope on dwv fittings, male adaptors, Clean out plugs, sometimes I'll use a them both, dope over the top of tape. When combined tape and dope will use on both dwv and plastis water pipe, but never dope alone on water pipe male threads.
Old 06-27-2007, 11:50 AM   #25
Longtooth's Avatar
Never heard of using both. You sound like a hella good plumber.
Old 06-28-2007, 11:21 AM   #26
Interesting info guys, thanks. my question ... i am putting a manifold together for my air compressor, combination for brass and gal steel. Will pipe dope and teflon work w/this application?
thx
rolldodge is offline   Reply With Quote
Old 06-28-2007, 11:24 AM   #27
Journeyman Plumber
For air compressor use tape only, don't use pipe dope.
Old 07-04-2007, 11:58 PM   #28
Just wanted to say 'thanks' for the idea of using teflon tape and also pipe dope on a water connection. I just could get a consistent seal with just tape, and the pipe dope seems to have made the difference (well, so far!).
steve771 is offline   Reply With Quote
Old 07-20-2007, 09:22 AM   #29
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
I didn't use tape, dope only on most of the threaded connections in my house when I built. I ended up redoing them with teflon tape as most of them leaked. Lesson learned.
Teflon dope on LP pipe. I used teflon tape on my PVC cleanout caps.
comp1911 is offline   Reply With Quote
Old 07-20-2007, 09:31 AM   #30
another example
Agree... Another example of company trying new invention on convention items for making bucks...
go with what is working and stay with tradition is a good idea most of the times.
KUIPORNG is offline   Reply With Quote
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 02:55 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 01:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
