Old 08-31-2006, 09:47 AM   #1
Teflon tape or pipe dope
I've read some of the posts in this forum and many plumbing books. Sometimes, I see recommendations to use tape, other times, to use pipe dope. I don't see any kind of pattern about when to use what.
Are there applications where teflon tape is better than using pipe dope (pvc, copper, iron, steel or brass / straight or tapered threads)?
chickenboo is offline   Reply With Quote
Old 08-31-2006, 06:50 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Tape should be used when dealing with plastic fitting mainly plastic male thread water fitting, reason being if you use pipe dope on plastic male threaded fitting for water supply, the dope tends to make the threads too slick causing overtighting of the fitting.
Now on plactis drainage fitting, pipe dope if fine to use.
Now we use a combo of teflon tape with pipe dope on all metalic male water fitting and pipe, this ensures it will have a possitive seal each and evreytime.
Ron The Plumber is offline   Reply With Quote
Old 09-18-2006, 01:17 PM   #3
Have you ever found situations where pipe dope caused any kind of chemical reaction with a plastic component that led to the part failing?
carlfino is offline   Reply With Quote
Old 09-18-2006, 03:15 PM   #4
Journeyman Plumber
Nope not in 25 years.
Old 09-18-2006, 04:47 PM   #5
World famous jerk.
Consequently, Rectorseal #5 is the shizzle as far as pipe dopes go!
mdshunk is offline   Reply With Quote
Old 09-18-2006, 06:42 PM   #6
Journeyman Plumber
We never use Rectorseal
Old 09-18-2006, 07:51 PM   #7
General Contractor
Regular old Teflon tape should not be used on gas piping. They do make a tape for gas pipe but it is more expensive than pipe dope.
Good old slic-tight pipe dope for me. but I know it's getting harder & harder find.
fqp25 is offline   Reply With Quote
Old 09-18-2006, 07:58 PM   #8
Journeyman Plumber
We use Megaloc on gas pipe no tape
Teflon tape with pipe dope on brass fitting.
Teflon tape on plastic water fittings male thread adaptors
Megaloc or teflon tape on plastic male threaded drainage fittings.
Old 09-18-2006, 10:32 PM   #9
I use teflon tape on most joints under 2" except gaslines. I don't even trust the yellow tape for gas. Over that size , pipe dope. I believe Rectorseal #5 is probably the best pipe dope compound around since I haven't seen Key Tite in quite a while. One thing about teflon tape though. Don't buy that $.39 junk stuff off the bargain bin shelf. I have seen some that was so thick, you couldn't even get it to stick to the threads.
majakdragon is offline   Reply With Quote
Old 10-08-2006, 05:34 PM   #10
mccoy
Guest
Posts: n/a
Which is best for transitioning from a threaded PVC to metal connection, teflon tape or plumbers thread compound?
Old 10-08-2006, 05:37 PM   #11
Journeyman Plumber
Teflon Tape if it's a water fitting, pipe dope if a drainage fitting.
Old 10-08-2006, 11:48 PM   #12
I blame ProWallGuy
Read the label. The label will tell you what you can use it on.
Rectorseal #5 is an oil solvent based product and will attack and weaken ABS plastics. Rectorseal T+2 is safe for ABS plastics as is Hercules Megaloc.
When using teflon tape, be careful with plastics. You can put too much on the male threads and when screwed into a plastic female fitting you can cause great pressure in the fitting and it will fail. Rule of thumb is, two wraps max. More is not better.
Double A is offline   Reply With Quote
Old 11-10-2006, 04:24 PM   #13
Plumb Dumb
winkydink's Avatar
Question
I saw no one mention the liquid Teflon.
Yet I see many plumbers using it.
Not sure which they are using it on.
Also when (what type of connections) should have NO tape or dope or liquid Teflon ?
thanks
wink
winkydink is offline   Reply With Quote
Old 11-10-2006, 08:50 PM   #14
Journeyman Plumber
thanks
wink
On compression joints, but sometime I will use pipe dope at the point of seal on a compression joint if it's brass. But it's not needed.
Old 06-22-2007, 11:45 AM   #15
'Shizzle' is new to me, I don't know if that's good or bad...
I'm trying to seal against off-road diesel fuel. Before you say 'Diesel fuel is diesel fuel,' let me tell you that it is NOT. The dye in off-road diesel attacks a lot of thread dopes. Rectorseal tells me NOT to use #5, but rather to use #7. Other manufacturers say, "Diesel is diesel." Anybody have experience with plumbing for off-road diesel fuel?
Paul in WI
paulm is offline   Reply With Quote
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 03:55 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 02:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
