Teflon Tape Or Pipe Dope - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2011, 06:19 PM   #1
Journeyman Wireman
Rewards Points: 150
Teflon Tape or Pipe Dope
I have a galvanized nipple threaded into a brass elbow that has a slow drip. I'm going to take apart and replace it. Should I use teflon tape or pipe dope when I reconnect. It currently has pipe dope residue on the threads. This nipple has been in place as long as I've owned the house, going on 20 years.
Any opinion on whether I should use a brass or galvanized replacement nipple?
Jupe Blue is offline   Reply With Quote
Old 05-21-2011, 06:24 PM   #2
Galvanized pipe is going to corrode and close up, it's just a matter of time. Replace it all, or in sections, as you can.
As for fixing the current leak, tape + dope will to do the trick. Brass nipple is preferable over galv as stated above.
VIPlumber is offline   Reply With Quote
Old 05-21-2011, 09:06 PM   #3
Rewards Points: 266
I personally prefer pipe dope (rectorseal) over teflon tape but have used both in the past.
Kind of odd the leak would just start all of a sudden?
junkcollector is offline   Reply With Quote
Old 05-21-2011, 10:17 PM   #4
Journeyman Wireman
Rewards Points: 150
Probably not odd that it started. It's a sloooow drip in a connection to my dishwasher. Located in sink cabinet. Lots of items being moved in and out, particularly the trash can. Probably got bumped one too many times.
Fixed now.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Pipe dope and teflon tape: if it's holding now, can I trust it? nilloc Plumbing 12 04-30-2011 02:28 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 10:29 PM
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 03:55 PM
