Teflon Tape Or Joint Compound Necessary? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-17-2011, 03:04 AM   #1
Teflon tape or joint compound necessary?
I just bought a new single hole Toto sink and a new Grohe faucet. There are two threaded connections, one from my hot/cold shut offs to the braided pipes coming from the faucet, and another between the pop up drain assembly and the drain flange piece.
Do I need to put anything on the threads like Teflon tape or joint compound?
The Grohe installation guide just says to make sure to seal underneath drain flange. I assume I should use plumber's putty for that.
Thanks, any advice is appreciated, it's my first home.
djgrant is offline   Reply With Quote
Old 06-17-2011, 06:18 AM   #2
Nothing needed for the faucet connectors, there is a rubber washer in the connector. Tighten finger tight plus maybe a 1/2 turn. I usually use plumbers putty on the pop up threads. Sometime it is fine without, sometimes a wee drip, so i do it as a matter of course.
Old 06-17-2011, 09:09 AM   #3
Rewards Points: 480
nothing is needed they have a seal in them.
del schisler is offline   Reply With Quote
Old 06-17-2011, 09:21 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Grohe faucets do not have a seal in their supplies.
You can even tell by looking at the picture.
They are brass on brass connection.
DJGRANT : The possibility of leaking depends mostly at this point on the condition of your angle stop where the supply would connect to it. If the outlet is still in good shape (no pitting or rust) then you'll probably be OK. Give it a shot and see what happens. If it drips a little, pull it off, and put a LITTLE BIT of pipe dope on the mating surface and try again.
If it still leaks come back and we can discuss options.
Journeyman Plumber
Old 06-17-2011, 11:12 AM   #5
Alan: the stops are brand new. :-)
Tape or Joint Compound bigwill Plumbing 4 05-27-2011 08:34 PM
Wrong type of Joint Compound or Tape bigwill Drywall & Plaster 5 05-18-2011 11:30 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
