Teflon Tape How Much? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2007, 02:16 PM   #1
Teflon Tape how much?
I'm redoing the plumbing on my pool pump. It's 1 1/2" to 2" PVC. There are 4 threaded male connectors that go into the pump and filter. I plan on using Teflon Tape. Just wondering how much I should use. How many layers?
dscott60 is offline   Reply With Quote
Old 07-21-2007, 02:25 PM   #2
at least 2
redline is offline   Reply With Quote
Old 07-21-2007, 08:38 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Or three or four is what I use.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 07-21-2007, 09:45 PM   #4
Remodeler
MinConst's Avatar
I think 3 is good number. It's what I use unless the fit is sloppy.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 07-22-2007, 07:40 AM   #5
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
It depends on the width of the teflon tape you are using. If you start at the second starting thread you want at least one full wrap all the way around that covers all the rest of the threads. On an inch and a half pvc male adapter that could be two wraps of 3/4" wide tape or three to four wraps of 1/2" tape.
MechanicalDVR is offline   Reply With Quote
Old 07-22-2007, 10:10 AM   #6
Home Improvement Guy
ron schenker's Avatar
My plumber uses pipe thread compound. Just goops it on.
ron schenker is offline   Reply With Quote
Old 07-22-2007, 03:55 PM   #7
Long-Time DIYer
Mike Swearingen's Avatar
I think that teflon tape is better than pipe compound on PVC threads.
I usually wrap a minimum of 3 flat wraps of 1/2" tape on that size.
Wrap the tape clockwise only on the male threads as the threaded ends face you.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Teflon tape or pipe dope chickenboo Plumbing 50 06-29-2011 09:16 AM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 02:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
