Old 06-05-2007, 12:35 AM   #1
Teflon tape adequate for spout diverter?
I have two shower tubs. The tub spouts have popup valves that diverts water to the shower head.
I was planning to use teflon tape for the threads on the pipe I screw the spouts on. But I read it was good to use pipe thread compound.
I am very paranoid about shower leaks now, and I wonder if teflon tape would be adequate seal for the spouts?
darsunt is offline   Reply With Quote
Old 06-05-2007, 02:50 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can use tape if you like, wrap clockwise around thread.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Teflon tape or pipe dope chickenboo Plumbing 50 06-29-2011 09:16 AM
Teflon Tape how much? dscott60 Plumbing 6 07-22-2007 03:55 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
