Teflon Tape - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2011, 11:45 AM   #1
Rewards Points: 18
Teflon Tape
I am hoping that I don't need to go to home depot again. I will be attempting to install a centerset faucet. I have a basin wrench, a challel lock and some silicone. The only item that I might need is teflon tape. Is this necessary for the threaded areas?
The old faucet had no tape anywhere and did not leak (rarely used though) The new faucet has a plastic drain tube, which I understand makes using tape unnecessary. With that said, the P Trap is metal (at this point) and of course the threads for the supply lines are metal.
Faucetguy is offline   Reply With Quote
Old 10-24-2011, 11:53 AM   #2
DIY staff
Rewards Points: 7,174
No teflon tape will be needed for that install unless the pop up assemble is a brass one with a threaded tail piece.
Sometimes plumbers putty is needed under the faucet if the faucet does not have a rubber gasket for the bottom where it meets the counter top.
If the top is real granite or marble--use an oil free putty---I get mine at the plumbing supply house--No idea if the stuff is available in a big box store.
Faucetguy (10-24-2011)
Old 10-24-2011, 12:01 PM   #3
Rewards Points: 18
The faucet has a flat part (not sure if it is plastic or rubber) that it sits on. Do I need putty or silicone for the ring that sits at the bottom of the sink around the pop up. I am guessing that I don't need the putty for the handles because they have rubber gaskets attached to them.
Old 10-24-2011, 12:07 PM   #4
DIY staff
Putty or silicone is fine under the pop up ring. I prefer putty---others swear by silicone---so use what you have on hand.
Old 10-24-2011, 12:11 PM   #5
Rewards Points: 18
Do I not need any putty for underneath the base of the faucet and under the handles? Based on your previous reply, I think the answer might be that I don't need it.
Old 10-25-2011, 09:00 PM   #6
DIY staff
I hope your are all done by now---but no you don't need any putty under your faucet because of the type of base on that one.
Old 10-26-2011, 07:29 AM   #7
Rewards Points: 18
I am done (I think) Initially, I had leaks coming from everywhere. I tightened the supply line nuts and that fixed two of the leaks. Then I had a bad leak by the J bend. I used some pipe dope and the leak is gone. Finally, I had a leak by the drain tube. I repositioned it and tightened and that seemed to work. I do have a new area that could be an issue. This morning, I noticed a little drop forming by the valves for the supply line. I will have to watch that one. I did not touch that connection as part of the install.
Old 10-26-2011, 06:29 PM   #8
DIY staff
Post picture of the problems if they occur----
Often the old shut off valves leak at the stem---most times a little tightening of the cap nut under the handle is all it takes to stop that drip.
Teflon tape or pipe dope chickenboo Plumbing 50 06-29-2011 08:16 AM
Pipe dope and teflon tape: if it's holding now, can I trust it? nilloc Plumbing 12 04-30-2011 01:28 PM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 09:29 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 01:50 AM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
