-   -   Teflon Tape (http://www.diychatroom.com/f7/teflon-tape-121139/)
Faucetguy 10-24-2011 11:45 AM
Teflon Tape
I am hoping that I don't need to go to home depot again. I will be attempting to install a centerset faucet. I have a basin wrench, a challel lock and some silicone. The only item that I might need is teflon tape. Is this necessary for the threaded areas?
The old faucet had no tape anywhere and did not leak (rarely used though) The new faucet has a plastic drain tube, which I understand makes using tape unnecessary. With that said, the P Trap is metal (at this point) and of course the threads for the supply lines are metal.
oh'mike 10-24-2011 11:53 AM
No teflon tape will be needed for that install unless the pop up assemble is a brass one with a threaded tail piece.
Sometimes plumbers putty is needed under the faucet if the faucet does not have a rubber gasket for the bottom where it meets the counter top.
If the top is real granite or marble--use an oil free putty---I get mine at the plumbing supply house--No idea if the stuff is available in a big box store.
Faucetguy 10-24-2011 12:01 PM
The faucet has a flat part (not sure if it is plastic or rubber) that it sits on. Do I need putty or silicone for the ring that sits at the bottom of the sink around the pop up. I am guessing that I don't need the putty for the handles because they have rubber gaskets attached to them.
oh'mike 10-24-2011 12:07 PM
Putty or silicone is fine under the pop up ring. I prefer putty---others swear by silicone---so use what you have on hand.
Faucetguy 10-24-2011 12:11 PM
Do I not need any putty for underneath the base of the faucet and under the handles? Based on your previous reply, I think the answer might be that I don't need it.
oh'mike 10-25-2011 09:00 PM
I hope your are all done by now---but no you don't need any putty under your faucet because of the type of base on that one.
Faucetguy 10-26-2011 07:29 AM
I am done (I think) Initially, I had leaks coming from everywhere. I tightened the supply line nuts and that fixed two of the leaks. Then I had a bad leak by the J bend. I used some pipe dope and the leak is gone. Finally, I had a leak by the drain tube. I repositioned it and tightened and that seemed to work. I do have a new area that could be an issue. This morning, I noticed a little drop forming by the valves for the supply line. I will have to watch that one. I did not touch that connection as part of the install.
oh'mike 10-26-2011 06:29 PM
Post picture of the problems if they occur----
Often the old shut off valves leak at the stem---most times a little tightening of the cap nut under the handle is all it takes to stop that drip.
