Tapping Water Line And Drain From Sink For Washing Machine? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2009, 01:43 PM   #1
Rewards Points: 408
Tapping water line and drain from sink for washing machine?
I want to move the washing machine in another room and conveniently(or not) the water lines for the kitchen sink and dishwasher are right there along with the drain. The water lines are only 1/2".
- Is it okay to tap into this for the washing machine?
- Would the facet be weak when the washing machine is on?
- Dishwasher and washing machine on at the same time, would that work going through a 1/2" line?
Thanks.
Tapping water line and drain from sink for washing machine?-drain.jpg   Tapping water line and drain from sink for washing machine?-washer.jpg
RyanD is offline   Reply With Quote
Old 06-27-2009, 04:32 PM   #2
Remodeler
MinConst's Avatar
You should be fine if nothing else is fed by the supplies. The drain should really be at least 2" pipe. Can't tell from the picture. And vented.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-27-2009, 08:25 PM   #3
Rewards Points: 1,088
Or, buy a HE washer as it'll require less water.
handy man88 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 05:11 PM
Tapping into water line Dave8 Plumbing 6 02-23-2009 08:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 07:40 PM
