Tapping Sound From PVC Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2011, 07:36 PM   #1
Tapping Sound from PVC Drain Line
I am hearing a rather loud "tap" sound when I run the top level fixtures. It sounds like it might be coming from a wall. From where I can hear it, the drain runs straight down into an expansion joint, where several other drains tie in, and then down into the sewer.
I have looked for signs of water in the basement but haven't seen or been able to feel any, from where I can reach my fingers up into the hole that the 3" drain comes through. Is it possible that the pipe is tight against the wood framing in the wall and the sounds I hear are the groans of thermal expansion/contraction?
The sounds stop when I stop using the drain, but I've noticed they seem to give one last "tap" when I step on the floor near the wall in question.
mforeman1 is offline   Reply With Quote
Old 02-25-2011, 07:44 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
In my house in a COLD climate the vent pipe/stack from the sink/tub goes into the attic and when I run hot water heat rises up it and it expands/contracts it and makes noise. Sounds like an expanding/contracting noise to me. Houses/wood expands/contracts with the seasons/changes in moisture so it may come and go.
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 08:11 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 02:51 AM
trickling water sound in the drain yfulmer Plumbing 2 11-25-2007 11:49 PM
