Tapping Pff Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 01:50 PM   #1
Tapping pff copper pipe
How difficult is it to tap off a copper pipe water line, actually two, one cold and one hot water feeds? I need to remove an old shampoo bowl from my basement but It will require tapping lines, not sure what tools or materials I may need
Jarrettdr is offline   Reply With Quote
Old 01-01-2012, 02:04 PM   #2
Rewards Points: 582
sorry but if you don't know what tools to use....I think you should call a plumber...and from your question not sure if you want to tap into a line or cap off a line??????
The Following User Says Thank You to ben's plumbing For This Useful Post:
Jarrettdr (01-01-2012)
Old 01-01-2012, 02:04 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Got a picture?
plummen is offline   Reply With Quote
Old 01-01-2012, 02:12 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Jarrettdr View Post
How difficult is it to tap off a copper pipe water line...
...not sure what tools or materials I may need
Everyone should know how to work with copper pipe and fittings.
Hiring a plumber will still often have merit.
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
Old 01-01-2012, 03:58 PM   #5
raylo32's Avatar
Rewards Points: 1,226
By "tapping off" I take it you mean you need to run hot and cold supplies to a new location? If so and if the pipes are easily accessible it isn't that hard to do and this might be a good time to learn. Basic tools needed are pipe cutter, sandpaper or copper pipe/fitting wire brush cleaning tools, torch, flux, and solder. Just cut pipes (take out small lengths to account for the new t-fittings) and solder in the t fittings. Then run pipes to new location. Read up (or ask here) about soldering and practice on some scraps before "going live". If not comfortable with this, by all means call a plumber.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
TheEplumber (01-01-2012)
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 10:12 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
