Tapping PEX Line For Ice Maker - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2009, 07:24 AM   #1
WaldenL's Avatar
Rewards Points: 268
Tapping PEX line for ice maker
How does one tap a PEX run for an ice maker? I'm used to the saddle clamp taps that drill themselves into the copper. One thought was to cut the pex and insert a piece of copper, say 6", just for the tap, but that seems silly. Thoughts?
WaldenL is offline   Reply With Quote
Old 09-15-2009, 07:53 AM   #2
Registered User
Termite's Avatar
You'd just need to install an appropriate pex fitting to transition to a tee. Can't do anything as simple as the old saddle/needle valves. A threaded connection as opposed to a pierced connection will give better water flow (no hollow ice cubes 2 years down the road).
Old 09-15-2009, 07:56 AM   #3
They make pex connectors for this both the crimp and shakbite style ,They carry them at the box stores at least mine do
clasact is offline   Reply With Quote
Old 09-15-2009, 08:43 AM   #4
WaldenL's Avatar
Rewards Points: 268
OK, that makes sense. Put a tee in there, the main flow goes straight, and then off the tee I just reduce the size to the tubing needed for the ice maker. Great! Off to the big box store I go again... and again... and again... :-)
Old 09-15-2009, 09:40 AM   #5
Home depot carries a 1/2 barb x 1/2 barb x 1/4 comp valve that would would perfectly.
scotty123 is offline   Reply With Quote
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Tapping into water line Dave8 Plumbing 6 02-23-2009 08:26 PM
hook up ice maker line. already have a valve on the floor behind fridge but...3/8" bakchoi Plumbing 5 11-25-2008 06:59 AM
Tapping into 3"DWV line under basement slab cshaffer Plumbing 3 04-22-2008 04:48 PM
Tapping a water line for fridge Statecowboy Plumbing 6 10-12-2006 11:45 AM
