Tapping Noise From Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2012, 04:00 PM   #1
Tapping noise from water line
Since I've been in my house (5 years) there has been a tapping noise coming from the area behind/above the gas water heater when it is heating water. I've heard of pipes "banging" before, but this sounds more like a drip or clicking sound. When the water heater fires up, it is more constant, and gradually it slows down until it stops entirely. I've seen those water hammer devices that you can sweat inline that absorb the pressure, but I'm not sure if that is what I need.
jamesbobo is offline   Reply With Quote
Old 07-08-2012, 04:02 PM   #2
the Musigician
DangerMouse's Avatar
Sounds like minerals "cooking" in the heater to me. How old is the unit?
DM
Old 07-08-2012, 06:11 PM   #3
Sounds to me like the expansion of your hot water line as the water heater is heating the water.
VIPlumber is offline   Reply With Quote
Old 07-08-2012, 06:32 PM   #4
Rewards Points: 1,580
Does it sound a bit like muffled popcorn or marbles bouncing around?
If so, likely mineral deposits in bottom of tank getting stirred up by heating.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
jamesbobo (08-12-2012)
Old 07-08-2012, 06:37 PM   #5
Thermal expansion.
If you can find the exact point source perhaps a lubricant between the surfaces that are rubbing together may help.
Old 08-12-2012, 06:49 PM   #6
I guess it was the mineral deposits...I flushed the tank out and I haven't heard it since. Thanks to everyone for their help!
Old 08-12-2012, 06:59 PM   #7
the Musigician
...and thank YOU for returning to let us know the outcome!
DM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 10:18 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
