Tapping Noise In Wall After Flushing Upstairs Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2008, 10:45 AM   #1
Tapping noise in wall after flushing upstairs toilets
We have two toilets upstairs. After flushing either toilet we hear a tapping noise in the walls on the main level of the house. The noise is a rapid tapping and tailors off within five or so seconds. We are trying to figure out the cause of this problem. Could this be a broken pipe strap? Should we be concerned that the pipes could separate?
John VH is offline   Reply With Quote
Old 01-21-2008, 11:12 AM   #2
A couple things come to mind. Since the toilet water is cold, the pipe (especially PVC) could be contracting as a reaction to the addition of the cold temperature. May just be the pipe scraping against a stud or a hanger/clamp. May also be water dripping down the pipe and hitting a fitting in the lower living area. Since it goes away so quickly, this would be my guess.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-21-2008, 11:24 AM   #3
it could also be somthing wrong with the shut-off switch were directing water to the toilet.... it happened to me before when I need to change the shut-off switch for a sink to get rid of a big noise.... however, it happens to me with the hot water supply switch though.... not sure if cold water switch will be the same...
KUIPORNG is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
wall hung toilets warnerww Plumbing 39 05-10-2007 06:35 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
flushing receptacals to wall a_theater_god Electrical 3 07-31-2006 04:01 PM
