Tapping Into Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2012, 12:17 PM   #1
tapping into water lines
we bought an older home ,1958, and it doesn't have a water line in the wall for our refrigerator ice/water dispenser. Can I tap into the water lines?
dcal is offline   Reply With Quote
Old 06-19-2012, 12:37 PM   #2
vln
Underwriter
No...
vln is offline   Reply With Quote
Old 06-19-2012, 03:16 PM   #3
yes. get a saddle and splice into your basement line. run the new water line either up through the floor or do as i did and route the new line through a air duct. use copper. do not use the cheap plastic lines as they crack and break easy. the saddle valve will probably leak. best if its not installed in a place where happen. might not leak at all for months or it might start slow drips right away. but you can do it. they make them for tapping into copper or iron pipe.
http://www.google.com/products/catal...d=0CJUBEPMCMAU
lost_punk is offline   Reply With Quote
Old 06-19-2012, 05:26 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Yes you can certainly tap into a water line for an ice maker. I suggest you do not use a saddle valve as the previous poster suggested. They are a leak waiting to happen.
What type pipes do you have and we can suggest a method that is reliable. Do you have access to a cellar or crawl space under the refrigerator area?
Coastal South Carolina
Old 06-19-2012, 05:37 PM   #5
Rewards Points: 13,300
Is there shut ff valves under the sink to the supply lines?
If so you can replace the valve with a double valve.
Old 06-19-2012, 06:09 PM   #6
Thank you for the reply. There is no basement or crawl space, the house is on
concrete slab. The sink is on the opposite side of the room from the refrigerator. I need to try to run a line through the attic or walls. Can this be done? Diane
Old 06-19-2012, 06:33 PM   #7
A "Handy Husband"
rjniles's Avatar
I will assume that the sink is on the exterior wall and the frig is on an interior wall. It is very hard to fish down an exterior wall due to being under the roof line at the eaves and insulation in the wall.
I would fish down to behind a bath vanity and run 1/4" flex copper and fish it down behind the frig. Install a shutoff valve (not a saddle valve) under the vanity and another valve behind the frig.
Old 06-19-2012, 11:21 PM   #8
Thank you for all the suggestions - I hope to try it soon. Diane
Old 06-20-2012, 06:53 AM   #9
Bill Kearney
Rewards Points: 1,174
You don't mention where you're located, be careful if you're putting a line in the attic if you have freezing cold winters. A line running through an uninsulated space risks getting frozen and bursting open.
wkearney99 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
slow hot water lines sobro Plumbing 3 11-05-2010 11:44 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
