Tapping Into Soil Pipe For Temporary Shower. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-15-2012, 06:43 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Tapping into soil pipe for temporary shower.
I'm plumbing in a temporary shower. The only practical pipe to tap into is a 3" soil pipe. Using fercos I added this section to weave in a 2" pvc pipe.
Now that I look at it, I'm worried that I created a snag for solids from the toilet. Could you look at my pic and tell me if I screwed this up?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-15-2012, 06:51 PM   #2
Roofmaster
Rewards Points: 2,210
You do know you need a trap, right?
Old 12-15-2012, 06:53 PM   #3
I have gas!
The shower plumbing penetrates the floor a couple feet away. The p-trap will be tucked up between the joists directly below the shower. I'm just checking before I glue it all in place. The venting, however, will be shared.
Old 12-15-2012, 07:55 PM   #4
Roofmaster
You are better off with a long sweep Y fitting if you can get it in there, Those short T'ees are for vents. Other than that, if you cut square, deburred and chamfered you should be OK. A 3 inch copper Y and 1/8th bend would be better, but this should work temporarily. 3 inch copper takes some serious heat output to sweat.
The Following User Says Thank You to jagans For This Useful Post:
Clutchcargo (12-16-2012)
Old 12-16-2012, 06:47 AM   #5
Rewards Points: 2,516
Is that a sanitary-tee on its back??
Tapping into soil pipe for temporary shower.-proper-placemet-wye-san-t.jpg   Tapping into soil pipe for temporary shower.-proper-placemet-wye-san-t-1.jpg
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
Clutchcargo (12-16-2012), Javiles (12-16-2012)
Old 12-16-2012, 09:29 AM   #6
I have gas!
Good to know. Thankfully I haven't glued it yet. I'll correct that.
Thanks guys.
Rain Shower - Exposed pipe in attic - in Canada??!! HELP! mattrichling Plumbing 14 01-03-2012 12:44 PM
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
Replacing shower drain all connectors, no pipe nkovach Plumbing 0 06-21-2010 09:15 AM
Solution for 1.25" drain pipe for removable shower? CZ DIY Plumbing 3 10-06-2009 10:20 AM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
