Old 03-20-2012, 10:12 PM   #1
Tapping into main water line
I want to put water to my detached garage by tapping into the water line going to my house, right after my submersible pump. I'm thinking I can just put a T in the line and be able to use my pressure tank in the house for the garage. I guess I'll need to take the check valve out from before the pressure tank. I think I would need to put in between the pump and the T. Does this sound right?
racinpig is offline   Reply With Quote
Old 03-21-2012, 08:15 AM   #2
Ideally, you should tap off after the pressure tank, otherwise you will need another pressure tank in the garage. Bury the lines below frost line, and i assume the garage is heated???? If not, make provisions for being able to drain the line.
Old 07-31-2012, 12:16 PM   #3
racinpig, you may want to check with the city/county in which you live regarding water to a detached building. We were planning to build my mother-in-law a detached unit in the backyard. I live in Contract Costa county in California, and they REQUIRE the installation of a separate meter AND a "Facility Reserve Charge", the sum total of which is $22,500!
Jim1961f is offline   Reply With Quote
Old 07-31-2012, 12:53 PM   #4
Not exactly the same thing, but I tapped into my water supply line to install a yard hydrant. It's about 20 feet from the house. I did not need a second pressure tank anywhere.
You will have to do something about the check valve. Since at the time I didn't yet have my plumbing final inspection, I couldn't remove it. So I took the guts out of it instead. That was four years ago and it's still that way. And I didn't have to add a check valve anywhere else.
md2lgyk is online now   Reply With Quote
Need to Replace Main Water Line through Foundation rbperrie Plumbing 0 10-22-2011 01:58 PM
How to shut off main hot water line? AlexnNotHandy Plumbing 7 10-12-2009 10:14 PM
Switch from 1/2" to 3/4" main water line? SanDiegoGuy Plumbing 10 04-17-2009 08:12 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
