-   -   Tapping into main water line (http://www.diychatroom.com/f7/tapping-into-main-water-line-137686/)
racinpig 03-20-2012 09:12 PM
I want to put water to my detached garage by tapping into the water line going to my house, right after my submersible pump. I'm thinking I can just put a T in the line and be able to use my pressure tank in the house for the garage. I guess I'll need to take the check valve out from before the pressure tank. I think I would need to put in between the pump and the T. Does this sound right?
Just Bill 03-21-2012 07:15 AM
Ideally, you should tap off after the pressure tank, otherwise you will need another pressure tank in the garage. Bury the lines below frost line, and i assume the garage is heated???? If not, make provisions for being able to drain the line.
Jim1961f 07-31-2012 11:16 AM
Detached Units and Separate Meters
racinpig, you may want to check with the city/county in which you live regarding water to a detached building. We were planning to build my mother-in-law a detached unit in the backyard. I live in Contract Costa county in California, and they REQUIRE the installation of a separate meter AND a "Facility Reserve Charge", the sum total of which is $22,500!
md2lgyk 07-31-2012 11:53 AM
Not exactly the same thing, but I tapped into my water supply line to install a yard hydrant. It's about 20 feet from the house. I did not need a second pressure tank anywhere.
You will have to do something about the check valve. Since at the time I didn't yet have my plumbing final inspection, I couldn't remove it. So I took the guts out of it instead. That was four years ago and it's still that way. And I didn't have to add a check valve anywhere else.
