Tapping Into Main Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2009, 07:36 AM   #1
Tapping into main drain
I am in the final stages of finishing my "Man Cave" in the basement. PROBLEM... I am installing a bar sink (bottom of sink 28" from floor) the drain I would like to tap into is approx 10' away. The drain (see pict) is 3" "Y" for the upstairs kitchen and 2nd floor bath. I have 5" from floor to "Y". There is also another drain that is used for the A/C. I am sure it connects to main drain with a "P" trap. QUESTION....Can I use the drain for the A/C or do I have to go the main drain line. If main line, then what would be the best way to tap in?
USAF Retired is offline   Reply With Quote
Old 05-23-2009, 07:02 PM   #2
The AC drain would depend if it is a sewer drain or a storm water drain
hayewe farm is offline   Reply With Quote
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 05:11 PM
Main drain water back ups destroyer427 Plumbing 7 04-07-2009 12:58 PM
Main Drain Assembley--What is This? wsuswim147 Plumbing 5 03-20-2009 05:41 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
