Tapping Into An Aerobic System - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2008, 04:34 PM   #1
Tapping into an aerobic system
I built a 2500 sqft metal building and framed an 1000 sq ft living area in it leaving me a 1500 sqft shop. Now I want to finish out the remaining 1500 ft into living space. Unfortunately I did not preplumb it for this addition and now I need to add 2 bathrooms. I have an aerobic system that runs the 1000 sqft living area now and I want to tap into that. I was wondering if I could run the plumbing out of the backside of the remaining 1500 sq ft shop and around the corner to tap into the existing aerobic system.
ebrooks is offline   Reply With Quote
Old 06-22-2008, 10:26 PM   #2
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
The deciding factor is whether or not your system is sized to handle the additional load from 2 more bathrooms. As long as you can get the proper slope on the drain pipe, connecting to the existing pipe before it enters your tank is fairly simple.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 06-23-2008, 09:15 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What the heck is an aerobic system?
Journeyman Plumber
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Radiant Heat System Leak? baeljb HVAC 4 05-21-2008 05:15 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
