Tapping Dishwasher Off Undersink Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2013, 01:55 PM   #1
Rewards Points: 85
Tapping dishwasher off undersink water heater
Forgive me if this has been addressed before...
I am looking at a house that has a "point of use" hot water heaters in the kitchen -- which is a long way from the main hot water heater. This small 6 gallon heater is set to a higher temperature than the main hot water heater and supplies water to the dishwasher. It connects to electric power through a standard outlet on a dedicated circuit. The water supply to this heater is off the hot water pipe to the kitchen sink.
I have never seen this done before, but was told that this was done to insure that the dishwasher would always have hot water when started -- without anyone having to run water until it gets hot. This also lets them set the gas hot water heater at a lower temperature.
Is this arrangement legal, and is a 6 gallon heater really large enough for a typical dishwasher fill? Does this arrangement "waste" energy by maintaining (with electricity) a very small tank of super heated water for use only by the dishwasher?
Perry401 is offline   Reply With Quote
Old 02-27-2013, 03:07 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Interesting questions. In commercial kitchens, 140* is required at the DW. This is usually achieved with a point of use booster or a dedicated 140* kitchen heater with tempering valves set at 120* at all outlets-except the the DW(140)
Some residential dishwashers have built in booster heaters that raise the temp to 140* If yours does- you're DW booster should do the work and wouldn't need the 6 gal htr.
As for legal, it would be OK in my area- if plumbed correctly, including the T&P line
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
