Old 05-27-2011, 02:33 PM   #1
Tape or Joint Compound
I installed a new shower and the cpvc fitting to the mixer valve is leaking. I used teflon tape on the cpvc threads and tightened twice but still leaks a little. I plan to buy a transition union and replace the cpvc fitting, it is 1/2 inch. Should I use teflon tape or pipe thread compound on the male threads on the transition union? The male threads will screw directly into the mixer valve and I will glue the cpvc supply line into the other end.
bigwill is offline   Reply With Quote
Old 05-27-2011, 03:29 PM   #2
Persona Non Grata
VIPlumber's Avatar
A union does not need tape or dope when done properly. Why not just back out your connection to the shower valve, clean it, tape & dope it, and reinsert?
VIPlumber is offline   Reply With Quote
Old 05-27-2011, 03:37 PM   #3
I actually need a transition male adapter to screw into the brass female mixer valve, not a union. I tried the cpvc male with teflon tape into the mixer twice but still leaks a little. I have been reading many opinions on which to use on male threads and I cant seem to get a most popular response. Some use only tape, some only dope, some use both on same fitting, some use 1 sort of combination on metal and something different on cpcv. Also if use dope on brass threads, rectorseal 5 or T plus 2?
Old 05-27-2011, 08:40 PM   #4
call me E
TheEplumber's Avatar
Using a cpvc male adapter with brass threads? Tape and dope your connections
Old 05-27-2011, 09:34 PM   #5
Persona Non Grata
VIPlumber's Avatar
Plastic into brass? Be very careful as cross threading is done quite easily.
Wrong type of Joint Compound or Tape bigwill Drywall & Plaster 5 05-18-2011 12:30 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
