Old 05-17-2011, 01:31 PM   #1
Tap Water High Alkalinity, High pH, High Copper
Our tap water in San Antonio TX tested over 420ppm Alkalinity, 9 pH and Copper 3.1ppm. I think the softener is set too high because I am totally thirsty after I start drinking it. Could this be causing these elevated numbers? What can we do to correct this problem if it isn't related to the softener?
kaegyg is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
