Old 02-25-2007, 03:44 AM   #1
tap turns water on when turning left or right?
I have a problem with a hot water tap and I don't think it is simply a washer replacement. The tap now has an unusual problem. I find it very hard to turn off. I can turn on the water by turning the tap to the right or left.
I still have to turn the tap right to turn it off but if I go too far the water comes back on.
What is the problem? Is it the valve seat?
Cheers
ebonysw45 is offline   Reply With Quote
Old 02-25-2007, 07:17 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What brand is this faucet?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-25-2007, 08:06 PM   #3
Sounds like a delta/delex with a broken handle to me.
gitnerdun is offline   Reply With Quote
Old 03-01-2007, 05:27 PM   #4
Diesel Fitter
Yes, take off the H cap remove the screw pull off the handle do the same to C put the cold handle onto the hot and see if this fixes it, if it does replace both.
2 things to think about
1 did you read the dissclaimer on this sight
2 do your shutoffs hold
mikemy6 is offline   Reply With Quote
Old 03-04-2007, 02:48 PM   #5
The stop on the cartridge may be broken off.
Replace the cartidge.
redline is offline   Reply With Quote
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Noise when turning on water anywhere in the house pkulkarni001 Plumbing 2 04-10-2006 05:20 PM
