-   -   tap turns water on when turning left or right? (http://www.diychatroom.com/f7/tap-turns-water-when-turning-left-right-6705/)
ebonysw45 02-25-2007 02:44 AM
I have a problem with a hot water tap and I don't think it is simply a washer replacement. The tap now has an unusual problem. I find it very hard to turn off. I can turn on the water by turning the tap to the right or left.
I still have to turn the tap right to turn it off but if I go too far the water comes back on.
What is the problem? Is it the valve seat?
Cheers
Ron The Plumber 02-25-2007 06:17 AM
What brand is this faucet?
gitnerdun 02-25-2007 07:06 PM
Sounds like a delta/delex with a broken handle to me.
mikemy6 03-01-2007 04:27 PM
Yes, take off the H cap remove the screw pull off the handle do the same to C put the cold handle onto the hot and see if this fixes it, if it does replace both.
2 things to think about
1 did you read the dissclaimer on this sight
2 do your shutoffs hold
redline 03-04-2007 01:48 PM
The stop on the cartridge may be broken off.
Replace the cartidge.
