Tap Spindle Over Rotates? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2012, 11:16 AM   #1
Post
tap spindle over rotates?
We have had this new brewer's mixer tap set for about 7 months now. I was very suprised to see the cold water tap starting to drip from the spout last week after turnung it off, since it has ceramic discs which are supposed to be the best type of tap washers/valves to get. Then I also noticed a squeaky rubber kind of sound when the cold water tap is actually turned, the hot water tap doesn't squeak. I found that putting downward pressure on the tap handle while turning it off invariably stopped the leak when turning it off. This week the tap started flowing water slightly when turned off: it's like the spindle now rotates past the off position and comes back on again when it reaches its rotation limit. I took it apart to check the ceramic discs and seals: they seem fine (lugs keep them in position), but the spindle clearly rotates past the 3/4 circle turn (to the off position) and opens up the gap between the discs again.
My question is: Is there any way to adjust the spindle position back where it was/should be, or is it just a faulty spindle that needs to be chucked?
skar is offline   Reply With Quote
Spinning spindle on my washing machine jwo Appliances 5 09-15-2011 04:14 PM
bearing for drive/blade spindle mhern09 Landscaping & Lawn Care 1 06-28-2011 01:51 PM
Spindle Question bobbie127 Carpentry 10 09-11-2010 09:36 PM
Doorknob attachment to spindle c2gene General DIY Discussions 6 10-26-2008 05:04 AM
spindle spacing jibber Carpentry 5 02-18-2007 08:30 PM
