Tap Into Existing Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2011, 08:54 PM   #1
Tap into existing pipe?
I want to put in a utility sink in my basement, my question is do I need to run pipe from the main water coming into the house, or can I cut and tie into the copper pipe that supplies another sink that is about 10 feet away? Will I be robbed of pressure? I will not be using the (1st) sink at the same time that I am using the new sink probably ever. Thanks for any replies.
BlaJoRon is offline   Reply With Quote
Old 10-23-2011, 09:10 PM   #2
You should be fine tapping into the nearest water lines.
VIPlumber is offline   Reply With Quote
Old 10-24-2011, 11:16 AM   #3
I appreciate the response.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Installing Wye to Existing Drain Pipe alladin15 Plumbing 1 08-17-2009 10:23 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
