Tap drain at basement floor?
I have a 4" drain that goes into the concrete basement floor. About one foot off the floor is a cleanout. I would like a/c condensate to drain into this pipe, but I would need to tap the pipe right at the floor line in order for gravity to work in the condensate line. Is it feasible to tap into the vertical drain right at the floor line? Here's where the plot twists into a 2-part question:
Between the furnace and the drain pipe is a door to the garage, so the condensate pipe needs to run below the door, along the threshold. I had thought of continuing the condensate pipe along the floor to the drain pipe, but then it occurred to me that the condensate pipe could be routed to encounter the door at a 2' height, make a "U" under the door, leaving the door area at an 18" height. In short, the"U" would simply be a bigger trap than normal, but it would still function as a trap, allowing me to tap the drain at the cleanout level, which I'm assuming is OK.
