Tankless WH With No Pressure Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2012, 09:07 AM   #1
Tankless WH with no Pressure Valve
Pulled the trigger on the tankless as a last min decision...
Long story short - its installed but i didn't see that my contractor installed the pressure valve?
should i be concerned about this ? I know he oversized the pipes for better overall water pressure - not sure if that matters either.
Its working fine - 10-15 sec lag on hot water which is expected but not sure if the valve not being installed is an issue.
Any direction/help on this topic is appreciated.
spaceboy is offline   Reply With Quote
Old 05-02-2012, 09:45 AM   #2
Which 'pressure valve' are you talking about? Temp & pressure relief valve or pressure reducing valve?
VIPlumber is offline   Reply With Quote
Old 05-02-2012, 09:50 AM   #3
From the looks if it - there is no valve whatsoever.
I was referring to the pressure relief valve that i thought was supposed to be installed.
The other service valves - I'm not concerned with as there are standard shut-offs there - just not the "fancy" versions that you can buy.
Old 05-02-2012, 09:55 AM   #4
Rewards Points: 13,450
More likly there's an over heat relay that shuts off the unit, There is no tank to blow up.
Old 05-02-2012, 09:57 AM   #5
so is the valve is a nice to have but not 100% needed ?
Old 05-02-2012, 10:11 AM   #6
What does your owners'/install manual say? I have and T&P on my Navien unit. It has a 1 gal storage tank inside.
Old 05-02-2012, 06:57 PM   #7
Rewards Points: 636
thank you spaceboy for understanding a tankless does not mean instant hot water out of tap
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-02-2012, 09:15 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 994
don't get it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-02-2012, 09:17 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 994
As per code must be installed according to manufactures specifications.
Old 05-02-2012, 09:46 PM   #10
Rewards Points: 264
Javiles, see the other 3 page long tankless water heater thread if you dare...
Spaceboy, when I was researching a tankless heater all the manuals I looked at called for a pressure relief valve, with many stating to contact the building department to see if you needed a temperature & pressure relief valve to meet code.
a_lost_shadow is offline   Reply With Quote
Old 05-03-2012, 09:05 AM   #11
Rewards Points: 3,130
My tankless has a T&P valve. It came with the unit when I bought it.
Old 05-03-2012, 09:52 AM   #12
I=E/R
a7ecorsair's Avatar
My tankless Richmond (Rheem) has a pressure relieve valve that was shipped with the unit. If there is some type of check valve that prevents expansion back to the cold water side, I can see the need for one.
a7ecorsair is offline   Reply With Quote
Old 05-03-2012, 12:43 PM   #13
Homerepairguy's Avatar
Rewards Points: 998
Here's a thought. Is it possible that the tankless unit could ever fail in a "heat water" condition? If yes, then there has to be a pressure relief valve in the system to protect from over pressure. I would install one for sure.
HRG
Homerepairguy is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Part2-Rumbling pipes and leaking pressure relief valve Homerepairguy Plumbing 9 04-24-2012 03:49 AM
main water valve or pressure regulator kzwbvn Plumbing 5 10-21-2011 06:40 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
do Pressure Reducing Valve fail? wazeaz Plumbing 5 02-10-2008 05:57 AM
