Tankless Water Unit Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2011, 05:53 AM   #1
Tankless water unit issue
I have a Noritz (model n-069m-ca) and every few days or so when taking a shower the hot water stops flowing. When I go to my tankless, the controller is flashing (no error code, just number 16 flashing for heat setting)
I have to power it off then on again, then it works fine.
ideas?
fjacky is offline   Reply With Quote
Old 03-09-2011, 09:04 AM   #2
Having taken a look at the manual, http://www.noritz.com/u/installation_manual__n_063s_od_n_069m_od.pdf,
I figure it could be a clogged water drain valve (p. 20). There are instructions in the link which tell you how to fix the problem.
Let us know how you get on.
VIPlumber is offline   Reply With Quote
Old 03-09-2011, 10:40 AM   #3
thanks for the info. I did what was described on page 20, although mine did not have a filter/packing. It only had a rubber washer and the plug itself. There was one big plug and a small skinny one. They seemed very clean. I included a photo.
We'll see if it did anything.
It looks like I already have the isolator valve kit too
Old 03-09-2011, 01:07 PM   #4
I think I'll try this too.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Tankless water heater Navien cr-210 ? dotmatrix Plumbing 40 09-13-2010 09:29 AM
Location for new Tankless water heater? bb_sam Plumbing 9 03-09-2010 09:09 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Tankless hot water sporatic until........ Ronin33 HVAC 15 06-05-2007 03:12 AM
