Tankless Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 04:54 PM   #1
tankless water heaters
what size electric tankless system would you need to fill a 50 gallon spa tub? Are they hard to install?
rd101345 is offline   Reply With Quote
Old 05-22-2011, 08:13 PM   #2
Rewards Points: 93
Don't worry as much about the heater itself..........most electric tankless heaters will need a dedicated circuit with anywhere from 30 to 100 amp being supplied.
Do you have this electrical capability? Most don't.
If you must go tankless..........look at natural gas or LPG.
George6488 is offline   Reply With Quote
Old 05-22-2011, 08:41 PM   #3
Rewards Points: 252
You're better off calling a pro on this. The size of the heater depends on several factors, like incoming water temperature, how much you want to raise that temp, the flow rate of the tub and what additional capacity you want to be able to use at the same time.
Gas will work better than electric, but either requires some work to be done that is usually beyond the DIY'er...
Marty1Mc is offline   Reply With Quote
Old 05-23-2011, 08:39 AM   #4
Rewards Points: 3,130
What Marty said. I suspect once you find out what it would cost you, you'd change your mind about a tankless heater.
Old 05-23-2011, 09:02 AM   #5
Rewards Points: 252
Agree on the cost. I looked into doing this instead of putting in a new tank. I have an all electric house with a 400A entrance (actually, two 200 A boxes). I have plenty of capacity. But, the cost of the installation was prohibitive since the wire would have to run 75 ft. from the box to the unit.
Old 05-23-2011, 10:09 AM   #6
This might be too much to deal with for a DIY project.
genie01 is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Your take on tankless water heaters NowItsShowtime Plumbing 15 12-25-2009 10:17 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Tankless Water Heaters zollander10 General DIY Discussions 4 07-27-2008 05:10 PM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 10:41 PM
