Tankless Water Heater Vent Adaptation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2012, 11:48 AM   #1
tankless water heater vent adaptation?
I have Rinnai 3/5 inch concentric vent for a tankless water heater. Replacing with a Rheem unit. Can I reuse the existing Rinnai vent assuming it will fit the Rheem unit. It's seems almost identical to the Rheem vent except the inner wall on the Rinnai vent is very heavy aluminum whereas the Rheem inner vent is stainless steel. Thanks
Mike in Arkansas is offline   Reply With Quote
Old 03-27-2012, 01:02 PM   #2
Rewards Points: 3,130
Replacing a Rinnai with a Rheem? That's like replacing a Mercedes with a Ford. But seriously, I would not use the Rinnai vent. The inner tube is the exhaust, and you could end up with carbon monoxide in your house if the fit isn't perfect.
Old 03-27-2012, 07:58 PM   #3
Install the new heater EXACTLY the way the manufacturer says. These heaters are way to sensitive and have way to many sensors in them for you to be effin around with them. Is the new unit a condensing heater? If so you can vent it w/ PVC. Cheap enough.
Bob Veela is offline   Reply With Quote
**I just installed my RHEEM ECO-SENSE 180DVN3 tankless water heater 57_Hemi Plumbing 21 01-03-2013 12:32 PM
Power Vent Water Heater Replacing Draft Vent polebarn HVAC 13 03-28-2012 07:12 PM
gas water heater vent into furnace vent??? Master Brian HVAC 2 05-08-2011 01:16 PM
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 01:21 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
