Tankless Water Heater Proper Pipe Size? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2009, 11:10 AM   #1
Rewards Points: 150
Tankless water heater proper pipe size?
Hi all,
My tankless water heater has 1/2" gas and water lines going into it. A plumber tells me that this type of heaters should have 3/4" lines for water and gas. Is this true?. Will it make a big difference for the water heater to go from 1/2" to 3/4" specially with the gas line?
gante is offline   Reply With Quote
Old 03-24-2009, 03:36 PM   #2
HVAC / Plumbing
Originally Posted by gante View Post
Hi all,
That plumber has seen the job. I haven't . He is probably correct
kenmac is offline   Reply With Quote
Old 03-24-2009, 03:58 PM   #3
joed's Avatar
Rewards Points: 11,982
What size of fittings are on the heater. If it has 3/4" fitting that have been reduced down to 1/2 then he is probably correct. Or this could be a smaller unit than he is used to seeing that only needs the 1/2 inch.
Old 04-06-2009, 09:59 AM   #4
Rewards Points: 256
Read the installation manual... it will have the specific requirements. Depends on brand, size, gallons/minute, etc..
moneymgmt is offline   Reply With Quote
Old 04-06-2009, 02:52 PM   #5
Registered User
Termite's Avatar
The pipe size is based on the gas demand. MOST tankless units' demand is high enough to warrant 3/4" gaslines. There is no one-size-fits-all answer...It totally depends on the demand as well as the length of the pipe.
Old 04-06-2009, 03:28 PM   #6
Rewards Points: 838
Hi all,
Is it working now?
LawnGuyLandSparky is offline   Reply With Quote
Change in pipe diameter at water heater blacksheiladog Plumbing 2 03-06-2009 01:12 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 09:49 AM
