Tankless Water Heater Problem
Did you change any portion of the gas supply plumbing? Are you sure that the shutoff valve is completely open. Is it possible that any part of the gas supply is obstructed, for example by excess Teflon tape across a pipe end?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
