I recently bought a fairly old house. It turns out our water pressure is to high (around 82 PSI) and we need to install a pressure reducing valve.
With this installation we also need to make a few other changes in order to be brought up to code in the related systems (expansion tank installed and seismic straps installed).
I have been thinking about getting a tankless water heater anyways for the efficiency gain so I don't want to do any work that isn't needed. From what I understand, the reason for the expansion tank is so when the pressure inside the system increases (from steam, or some other issues) the water will go into the tank instead of backflow into the cities pipes.
My questions are, if I go with a tankless water heater, do I still need the expansion tank?
If I don't get the PRV, will that have an adverse effect on the efficiency of a tankless water heater because of a higher GPM?
