Tankless Water Heater Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2008, 11:48 AM   #1
Tankless Water heater Help
Hi everyone i have an oil fired hydro system in my house, its 6 years old,i want to change the way we heat water ,( i spent from april until now about $1600 to heat water) from a 80 gallon tank to a tankless system, i have space in this room but it has 2 oil tanks there, does anyone know if i can install it in the same room as the hydro heating system?...thank you
karfista is offline   Reply With Quote
Old 09-02-2008, 05:10 PM   #2
Are you looking to put an oil fired tankless water heater in?
jerryh3 is offline   Reply With Quote
Old 09-03-2008, 07:42 AM   #3
no... liquid propane
Old 09-04-2008, 05:39 PM   #4
I am installing two NG units and as far as I know, you can get a DV (Direct Vent) or a Concentric model, which will intake and vent through CAT III piping directly out of the room, as long as you install the heaters away from flamables per instructions (give proper distances), you should be ok, since they vent and intake through the outside, instead of intake inside and vent through the outside. You can actually install the two versions above with flamable gas in the air, or tight spaces, since the vent/intake configuration is outside. You have to check clearances and install instructions, go to a manufacturesrs webside and look through the install manual for nuances.
Philip_Soldat is offline   Reply With Quote
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 11:41 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
tankless hot water heater bobo Plumbing 3 01-02-2007 06:34 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
