-   -   Tankless Water heater Help (http://www.diychatroom.com/f7/tankless-water-heater-help-26144/)
karfista 09-02-2008 10:48 AM
Hi everyone i have an oil fired hydro system in my house, its 6 years old,i want to change the way we heat water ,( i spent from april until now about $1600 to heat water) from a 80 gallon tank to a tankless system, i have space in this room but it has 2 oil tanks there, does anyone know if i can install it in the same room as the hydro heating system?...thank you
jerryh3 09-02-2008 04:10 PM
Are you looking to put an oil fired tankless water heater in?
karfista 09-03-2008 06:42 AM
no... liquid propane
Philip_Soldat 09-04-2008 04:39 PM
I am installing two NG units and as far as I know, you can get a DV (Direct Vent) or a Concentric model, which will intake and vent through CAT III piping directly out of the room, as long as you install the heaters away from flamables per instructions (give proper distances), you should be ok, since they vent and intake through the outside, instead of intake inside and vent through the outside. You can actually install the two versions above with flamable gas in the air, or tight spaces, since the vent/intake configuration is outside. You have to check clearances and install instructions, go to a manufacturesrs webside and look through the install manual for nuances.
