Old 08-18-2009, 11:46 AM   #1
Tankless Water Heater in Crawl Space?
The log house I'm building will have a propane tankless water heater (Rheem). Can these be installed in a crawl space? It would certainly simplify things if it could. The crawl space is 4 feet high.
Old 08-18-2009, 12:57 PM   #2
GC/Master Plumber/Mech
I wouldn't install in a crawl space.
They do make exterior mount systems unless freezing is an issue.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-19-2009, 07:56 AM   #3
Thanks for the info. Unfortunately, freezing is very much an issue.
UPDATE: I contacted the manufacturer. They said crawl space installation is fine.
Old 08-20-2009, 07:54 AM   #4
Just be sure there is adequate oxygen supply, adequate ventilation of exhaust gases, and no danger of freezing down there.
Some models may use a concentric dual pipe through a wall to achieve the first two.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 08-20-2009, 08:36 AM   #5
The model I have uses the concentric supply/vent arrangement. As for freezing, I certainly hope that's not an issue - all my plumbing is down there.
Old 08-20-2009, 10:08 AM   #6
Chicago, IL
Michael Thomas's Avatar
A couple of thoughts:
1) Some manufacturers recommend/require a backdraft damper if you are installing in a freezing climate, this is especially important if there is only a short run to the exterior.
2) There's a lot of electronics and other assorted moisture sensitive componets in these heaters, if this crawlspace is "damp", I'd be leery of installing a tankless unit down there, in my Chicago climate I frequently see corroded equipment in crawl spaces, and it's often equipment such as conventional tank type water heaters much less sensitive than tankless units.
3) I've put together a webpage on my experience with tankless units (I like them, but they are intolerant of incorrect installation), you may find it useful:
Tankless Water Heater Installation FAQ - Paragon Home Inspections Evanston / Chicago / Skokie / Wilmette / Morton Grove / Glenview / Northbrook / Illinois
___________________________________________
I’m paid to be suspicious…
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 08-20-2009, 02:28 PM   #7
Thanks for the link.
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
