Which TANKLESS Water Heater Is Best? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2008, 11:03 AM   #1
Rewards Points: 164
Which TANKLESS water heater is best?
Looking into buying tankless water heater which brand and model do you reccommend?
68MHJCs is offline   Reply With Quote
Old 02-14-2008, 12:34 PM   #2
From this and other Forums, Rinnai seems to get the best reviews. To decide what model you need, you need to know what you will be expecting the unit to supply. Hopefully, you do not have hard water or lots of minerals in your water supply. These conditions are a problem for tankless heaters and are not recommended. If you are having one installed, make sure you use someone who does service on them. Many Plumbers will install, but not service them since they are very technical and there are warranty concerns.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-14-2008, 11:41 PM   #3
Rewards Points: 164
Do you not reccomend buying one?
Old 02-15-2008, 05:06 AM   #4
Master Plumber
Rewards Points: 150
We install Noritz 7.51 gpm gas units only and have had no problems with them if they are gas sized properly. Noritz is supposed to only be available to the licensed plumbing professional. It is not a DIY project in my opinion.
jpplumber is offline   Reply With Quote
Old 02-15-2008, 09:47 AM   #5
Rewards Points: 164
No gas... electric I would need.
Old 02-18-2008, 05:33 PM   #6
mtm
Rewards Points: 18
Bosch (spelling?) Never read/heard anything good about them.
mtm is offline   Reply With Quote
Old 02-18-2008, 07:37 PM   #7
Send a message via AIM to Marlin
Bosch is total garbage. I don't like tankless heaters in general and as for the electric ones I always recommend agaisnt them unless it's a point of use heater for a garage or something.
What size is the service coming into your house? If it's 150 amps you might eeak by the power requirement for the thing but it's pushing it. 200 and you should be alright.
Marlin is offline   Reply With Quote
Tankless Water Heater bcdad Plumbing 4 02-15-2008 12:12 PM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 11:41 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
tankless hot water heater bobo Plumbing 3 01-02-2007 06:34 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
