Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2012, 08:26 AM   #1
Hi everyone. I am switching from a traditional to a tankless water heater. My question is, my cold main is 1-1/2 and the hot main is 1". The lines going to the old heater are 1". The new tankless heater only has 3/4" ports. Can I just reduce from 1" to 3/4" on the hot and cold side? Thanks.
MJI22 is offline   Reply With Quote
Old 08-26-2012, 08:43 AM   #2
Rewards Points: 13,450
Unless you have a very large house or multi storys it should be fine. By far most homes all use a 3/4 main runs to the supplys.
MJI22 (08-26-2012)
Old 08-26-2012, 08:46 AM   #3
Thanks joe. This is a restaurant though. The main coming in is 1-1/2" the hot main is 1". I just wanted to make sure u can go from 3/4" to 1" on the hot outlet of the heater.
Old 08-26-2012, 09:45 AM   #4
Then my info may be wrong. Not sure how it works were you are but around here any commecial work must be done by a licenced plumber, and needs a permit.
If this unit is sized wrong then there's going to be repercusions.
Your going to need way more flow and higher temp. then just a house would use.
Old 08-26-2012, 09:58 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 556
Not only what joe said but using residential equipment in a commercial application will void the warranty.
Old 08-26-2012, 12:43 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
Hope its gas, and as previously mentioned, calculation need to be made, the switch could have performance and safety issues, if you install the wrong unit.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Tankless Water heater, worth it?? zacker HVAC 23 01-04-2012 11:34 AM
relocating water heater location going tankless bstinson Plumbing 2 12-07-2011 10:00 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
