Old 08-16-2009, 02:51 PM   #1
Tankless Water Heater on 150 amp House?
So I'm doing a rush rush rush job at reasearching whether or not to do a tankless or a tanked water heater... (garage flooded this morning).
I'm looking at purchasing a Titan N-180 Tankless water heater which calls for (I guess) two 220 lines for a maximum of 77amps.
specs from titantankless.com: N-180 * 18KW * 220/240volts * 77amp
Is this going to be okay for my house which only has 150amp service? There's a good change I will run hotwater, dryer, AC and possibly stove at same time... maybe.
deeze is offline   Reply With Quote
Old 08-16-2009, 04:09 PM   #2
I would not do it. Buy a good tank heater.
jerryh3 is offline   Reply With Quote
Old 08-16-2009, 04:12 PM   #3
GC/Master Plumber/Mech
You might post in electrical section so that a sparky (electrician) can help you better with amp load.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-16-2009, 04:13 PM   #4
Question
Why not?
Old 08-16-2009, 04:15 PM   #5
Excellent idea?
So what's your opinion on tankless vs tanked?
Old 08-16-2009, 04:20 PM   #6
Originally Posted by deeze View Post
Why not?
I think you pointed out the most obvious reasons. You would be using half your rated service with the water heater. Turn on the dryer, A/C, and stove and you may be looking at a tripped main breaker. Plus, this most likely will require three double pole breakers which could be an expensive install depending on your existing setup.
Old 08-16-2009, 04:25 PM   #7
Excellent idea?
If it were me I would go with a gas fired tankless over electric, otherwise replace the WH.
Old 08-16-2009, 07:50 PM   #8
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
Replace the tank. You will have less problems in the future and its alot cheeper.
lonsplumbing is offline   Reply With Quote
Old 08-17-2009, 03:24 PM   #9
Replace the WH and include a Redytemp with the installation which will allow you to have hot water instantly during regular ussage times using the onboard timer and use the push-button on-demand operation during other times. Doing so minimized our hot water waiting no matter what time of day it was.
DIY4WIFE is offline   Reply With Quote
Old 08-17-2009, 10:00 PM   #10
Fun DIY project...
I wanted to use the braided flex for both connections but it just didn't work out on the cold side. The bend would have been too hard.
I had to replace the shut-off valve along with the water heater. Pretty bad when the valve failed as well as the tank... it made the interim time a bit of a pain.
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 03:59 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
