-   -   Tankless Water Heater on 150 amp House? (http://www.diychatroom.com/f7/tankless-water-heater-150-amp-house-51007/)
deeze 08-16-2009 01:51 PM
So I'm doing a rush rush rush job at reasearching whether or not to do a tankless or a tanked water heater... (garage flooded this morning).
I'm looking at purchasing a Titan N-180 Tankless water heater which calls for (I guess) two 220 lines for a maximum of 77amps.
specs from titantankless.com: N-180 * 18KW * 220/240volts * 77amp
Is this going to be okay for my house which only has 150amp service? There's a good change I will run hotwater, dryer, AC and possibly stove at same time... maybe.
jerryh3 08-16-2009 03:09 PM
I would not do it. Buy a good tank heater.
Plumber101 08-16-2009 03:12 PM
You might post in electrical section so that a sparky (electrician) can help you better with amp load.
deeze 08-16-2009 03:13 PM
Why not?
deeze 08-16-2009 03:15 PM
Excellent idea?
So what's your opinion on tankless vs tanked? :)
jerryh3 08-16-2009 03:20 PM
Originally Posted by deeze (Post 315227)
Why not?
I think you pointed out the most obvious reasons. You would be using half your rated service with the water heater. Turn on the dryer, A/C, and stove and you may be looking at a tripped main breaker. Plus, this most likely will require three double pole breakers which could be an expensive install depending on your existing setup.
Plumber101 08-16-2009 03:25 PM
Originally Posted by deeze (Post 315229)
Excellent idea?
If it were me I would go with a gas fired tankless over electric, otherwise replace the WH.
lonsplumbing 08-16-2009 06:50 PM
hot water tank
Replace the tank. You will have less problems in the future and its alot cheeper.
DIY4WIFE 08-17-2009 02:24 PM
Replace the WH and include a Redytemp with the installation which will allow you to have hot water instantly during regular ussage times using the onboard timer and use the push-button on-demand operation during other times. Doing so minimized our hot water waiting no matter what time of day it was.:huh:
deeze 08-17-2009 09:00 PM
Final project
Fun DIY project...
I wanted to use the braided flex for both connections but it just didn't work out on the cold side. The bend would have been too hard.
I had to replace the shut-off valve along with the water heater. Pretty bad when the valve failed as well as the tank... it made the interim time a bit of a pain.
http://www.dnscompanies.com/images/carreraday/tank.jpg
