Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2012, 08:11 PM   #31
Rewards Points: 636
ohm corsair what to say but feel the resistance
some get it and some don't
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-02-2012, 08:41 PM   #32
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by jaydevries View Post
hey thadsabb a.o.smith has a hybread that has both on demand with small water heater here is a link
http://www.hotwater.com/water-heater...xt-hybrid-gas/
and you guys still must not understand what the recurculating pump does for a on demand and if the you read the link and watched the video and still do not understand it i am not going to try here is another video for you
http://video.pbs.org/video/2195214406/
and the other thing the recurculater pump does is get rid of cold pockets and give you the instant hot water that most people think a tankless is
I'm not trying to be argumentative, but If you watched the video, you still have to WAIT for hot water.
It seems pretty simple to me that these videos are people who are trying to save water, because there is NO WAY that a recirculating pump can run 24/7 on a tankless water heater without a storage tank. NO WAY.
Journeyman Plumber
Old 05-02-2012, 08:47 PM   #33
Missouri Bound's Avatar
Agreed..100%.. Without a storage tank there would be no hot water to recirculate, since there is no water actually RUNNING through the tankless coils.
Do you want it your way or the right way?
Old 05-02-2012, 08:52 PM   #34
Doing it myself
Alan's Avatar
FURTHERMORE, if you hook it up this way without a demand switch and leave it running 24/7, guess what the flow sensor inside of your tankless water heater is going to tell the heating device to do?
Journeyman Plumber
Old 05-02-2012, 08:54 PM   #35
Actually it should do nothing unless a tap is opened. But running it continuously would finally just circulate cold water.
Old 05-02-2012, 08:57 PM   #36
Rewards Points: 636
umm hello the pump is off untill you push button check this video out
Old 05-02-2012, 09:03 PM   #37
Not sure what point you are making here. The recirculating pump won't do anything with a tankless water heater....no matter how long or short it runs.
Old 05-02-2012, 09:03 PM   #38
Doing it myself
Alan's Avatar
That's what i'm saying. So you have to push a button. . . and wait for the cold water to purge out of the hot water line before you actually get hot.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
hammerlane (05-03-2012)
Old 05-02-2012, 09:05 PM   #39
Doing it myself
Alan's Avatar
If you pipe it back into the cold supply like a normal water heater, and run a pump, the flow sensor will have the water heater on "heat mode" the entire time the pump is on, because there will always be water flowing through the heater.
Journeyman Plumber
Old 05-02-2012, 09:21 PM   #40
Ahhh....got it
Old 05-02-2012, 09:23 PM   #41
I=E/R
a7ecorsair's Avatar
I still have no idea why any residence would need or want a tankless water heater.
Why does anyone need a smart phone or iPad if you have a land line and a laptop
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
jaydevries (05-02-2012)
Old 05-02-2012, 09:27 PM   #42
Good question. Nobody NEEDS a smart phone or Ipad....not that that has anything to do with my question. Tankless water heaters are over rated.
Old 05-02-2012, 09:30 PM   #43
Rewards Points: 636
ok so what part of that does not make sense? and here is just one scenario
my bathroom is 80' of pipe away from tankless instead of turning on faucet and waiting a minute or so letting water run down drain until it gets hot. i walk into bath and motion sensor or manual switch turns on recirculating pump and creates flow switch on heater to turn on running hot water up to faucet and putting cold water back into cold supply "instead of down the drain" then when hot water hits faucet bypass sensor recirculating pump turns off. then i finish my paper work and like a good boy i wash my hands and what is this instant hot water wow no waiting over a minute that is amazing. so like a curios little guy i am i have to look under sink to see if they got one of those instant hot boxes that seem to only hold up a few years and make the meter spin so fast and nothing no little leaking box,but what do i see a little pump using under a watt of electric.
no saving the water umm not a big deal pennies down the drain,but instant hot water in a i want it now world priceless
Old 05-02-2012, 09:32 PM   #44
Rewards Points: 636
corsair in a month tell him how over rated they are by posting savings on gas and electric bill
Old 05-02-2012, 09:36 PM   #45
...and you think that little pump is what is making the hot water?....and you think it's saving you money? When that little pump runs it tells the energy hog tankless to kick on, and that's much worse if it's electric rather than gas....and you still waited a minute for the water, just did something else while waiting.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Tankless Water heater, worth it?? zacker HVAC 23 01-04-2012 11:34 AM
relocating water heater location going tankless bstinson Plumbing 2 12-07-2011 10:00 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
