Old 04-02-2012, 07:26 AM   #1
DIY hobbyist
Tankless water heater
Do tankless heaters really save you money on electric. I see that they pull more AMPS. Is it worth installing one ?
ggold is offline   Reply With Quote
Old 04-02-2012, 10:37 AM   #2
Most definitely, unless you would have to upgrade your electric service. That might add enough cost to make it not worthwhile to do. I have a tankless heater, though it is gas and not electric. Installed it myself. I'll never go back to a tank-type.
One consideration for installing a tankless that's often overlooked: if you have hard water, it will ruin the unit in a short time unless you have a water softener.
Old 04-02-2012, 10:57 AM   #3
Tankless are definitely more efficient. It is the potential cost to put one in that can be prohibitive. I looked into one when I replace my water heater recently but it wasn't worth it. Needed to upgrade my gas line, run a circuit for the powered vent and modify the exhaust flue. After all that I said forget it and just went with a more efficient tank version. Besides, the tankless are more complicated and tend to have more problems. If you have a recirc pump in your system it may not work with the tankless because it doesn't draw enough water to kick the unit on.
NitroNate is offline   Reply With Quote
Old 04-02-2012, 10:57 PM   #4
Master Plumber
Javiles's Avatar
gas yes electric no
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Tankless Water heater, worth it?? zacker HVAC 23 01-04-2012 12:34 PM
relocating water heater location going tankless bstinson Plumbing 2 12-07-2011 11:00 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 09:49 AM
