Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2011, 02:29 PM   #1
Tankless water heater
I have an electric Titan tankless water heater that was not heating the water as fast as it should. The manufacturer replaced the water heater. The new water heater is not working at all now. Does any one know what could be wrong. The water heater is getting power. We are looking into what is wrong. The question is do electric tankless water heaters have to have cleaning and maintence done on regular bases?
tgillis is offline   Reply With Quote
Old 09-18-2011, 02:36 PM   #2
Short answer is yes.
VIPlumber is offline   Reply With Quote
Old 09-18-2011, 02:43 PM   #3
Code05's Avatar
Rewards Points: 1,104
Originally Posted by viplumber View Post
short answer is yes.
Code05 is offline   Reply With Quote
Old 09-18-2011, 03:10 PM   #4
fabrk8r
fabrk8r's Avatar
All the installation/owner's manuals for tankless water heaters that I have seen do a pretty good job of explaining how the maintenance needs to be preformed, the recommended schedules and why it's important.
I would like to add that if the water heater was installed with the proper service valves the flushing process is very easy to perform if you have a small submersible pump, some short lengths of hose (rubber washing machine supply hoses work well), a couple gallons of white vinegar and a bucket.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Tags
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Is a tankless water heater more efficient? diyreader Plumbing 10 04-26-2011 05:34 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
