Old 10-03-2012, 06:23 PM   #1
tankless toilets
how well do the work & flush? Best place to buy?
aprylgarmon is offline   Reply With Quote
Old 10-03-2012, 09:34 PM   #2
tankless toilets
Go a picture or at least a web site.
Sure your not talking about a one piece toilet and tank, not a tankless one.
Old 10-03-2012, 10:16 PM   #3
tankless toilets
help me understand
Old 10-03-2012, 10:19 PM   #4
tankless toilets
are you are talking about the toilets you see in restaurants and such with a flush valve or are you talking about the ones with a pressure tank inside the back?? for the flush valves you need a 1" line to feed those for them to work properly.
The Following User Says Thank You to DannyT For This Useful Post:
ben's plumbing (10-03-2012)
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 01:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 07:07 AM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 11:41 PM
