Tankless Series Or Paralell - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 04:45 PM   #1
Tankless Series or paralell
If I have an application where a large Hot water GPM is needed such as a healthclub with multiple showers, Would it be better to pipe then in parrellel or in series? They are piped in parralell now but are having issues with inconsistant hot water temps?
Sarm is offline   Reply With Quote
Old 01-20-2013, 04:55 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
You want to put tankless heaters in series?
Old 01-20-2013, 05:11 PM   #3
Plumber
Rewards Points: 452
Do you have a storage tank?
http://www.rheem.com/pdfs/_temp/11000series/11120.pdf
Old 01-20-2013, 06:40 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Don't forget that when someone uses the tankless heater, they will get a hot shower. Once they turn it off, the line is full of hot water. When the next person turns on the water, they will get full hot, but there is also a delay (time varies most common I hear of is 3 seconds) where the heater has to sense a flow of water to turn on. That means you get hot hot hot.... cold cold cold... and then hot ---------------
Perhaps this is the issue that you are having?
Having them plumbed in parallel would not give you inconsistent temps unless there is something wrong with the unit.
Journeyman Plumber
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 01:21 PM
Make the jump to tankless? Recommendations? acerunner Plumbing 8 09-26-2010 10:27 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 11:41 PM
