Tankless ODW Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 09:20 AM   #1
Rewards Points: 31
Tankless ODW issue
We recently had a Quietside tankless HWH installed. I noticed that the unit cycles on (but does not fire) when there is a cold water only demand.
Is the unit most likely detecting water flow within the house on the inlet side and cycling on even though there is no demand for hot water? If so, is an inlet side check valve the solution? Thanks.
Rustygaff is offline   Reply With Quote
Old 01-24-2013, 11:31 AM   #2
SuperJETT's Avatar
Rewards Points: 156
Is it possible you have air in some hot water lines still after installation?
If you used some cold water, the cold line should see some pressure drop and the air would expand slightly pushing some water back through the HWH and the opposite direction when you turn the cold off and pressure returns to normal.
I'd flush all hot water taps just to rule that out.
SuperJETT is offline   Reply With Quote
Point of use vs Whole Home Tankless Electric joergeske Plumbing 1 09-30-2010 04:52 PM
Make the jump to tankless? Recommendations? acerunner Plumbing 8 09-26-2010 10:27 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
